2002 Jeep TJ 4.0, 79,000 miles
Check engine codes P0172 and P0175 (bank one and bank two running rich)
Ok, so replaced the coolant temperature sensor today and the plugs with XP 985's in the hope that it would be a quick fix. No such luck. Still getting P0172 and P0175 codes. The jeep is running great. No loss of power, no hesitation. If the CEL wasn't coming on, I would not know there was a problem based on how it is running. The only abnormal issue I have is a bit of a hard start when the engine is cool, but that makes sense to me since the jeep is losing pressure at the fuel rail schrader valve.
Have cleaned the IAC valve, replaced the purge valve, TPS, MAP, IAT sensor, coolant sensor, thermostat, plugs, upstream O2 sensors, air filter and cleaned the throttle body. All sensors are Mopar, plugs are XP 985, purge valve is Mopar, 02 sensors are NTK and thermostat was an OE 195 degree.
I have not installed anything on this jeep from Autozone.
What am I missing?
The only problematic data I have is a bit of an extended start when cold, P0172 and P0175 codes (both banks running rich) and fuel pressure that drops at the rail after priming (not starting).
43 PSI at the schrader valve on the fuel rail after priming
33 PSI after 1 minute 30 seconds (still with engine off)
23 PSI after 4 minutes and 30 seconds
0 PSI after 25-30 minutes
49 PSI at idle
Please respond with advice. Love this old TJ, but seriously considering lighting it on fire.
What am I missing?
49 PSI at idle
