Hello,
So I needed to replace my ODPA and my camshaft position sensor this morning on my 2004 Wrangler TJ 4.0 (manual tranny). I had some lateral play in the pulse ring and decided to go ahead and do some preventative maintenance. I also did my spark plugs (replaced with Autolite APP95) since they had not been replaced in a long time. I followed instructions on this forum for RMETeeJay and everything went fine. I started up the jeep when the work was done and everything was great. A little while later I needed to run an errand and decided to take the jeep. Everything started and ran fine up to the store. When I was leaving... the Jeep wouldn't start. I turned it over a couple times and pumped the gas and finally got the jeep to start. Again... jeep ran fine all the way home, sounded great, shifted great no sputtering no nothing.
So, I got home and parked it and now I cannot get it to start at all. The battery is fine... tested it on my multi-meter and I am getting 12.5 volts. All electricals are working fine. Now... let me say... I have been noticing my jeep struggling a bit to start PRIOR to the work I did this morning and have a gut feeling my starter might be going bad. Could it be my starter? Could it be from the work I did on it this morning? I tried testing my starter and I don't seem to be getting any constant power to it. Any advice on what to troubleshoot would be appreciated. Thanks.
