Ok so that confirms it. Mine won't start unless the clutch is pressed in any configuration either.Canadian model here, but mine won't start with clutch out in any configuration
Thanks for that. Didn't know that. Also, I should clarify for the OP that I don't remember if you have to pull the fuse or put it in to get the bypass to work...the 4x4 light staying on was a no-go for me.Only Rubicons will start with the clutch out in 4L.
All others have to use the bypass fuse to override the clutch switch.
In the case of a failed hill climb (hill steep enough to need the low box) it's best practice (here in the U.K.) to hold the vehicle on the foot brake select reverse and start the vehicle in gear to avoid the vehicle rolling back out of gear and potentially out of control.I was going to ask WTF were they thinking in regards to Jeep allowing the Rubicon to do that. Maybe it's OK because the Rubicon 4lo ratio is so low that the engine will easily turn over and when the engine gets to running the chances of the Jeep quickly leaping onto something or someone is pretty slim to none. I am kinda surprised the lawyers wouldn't put a stop to this immediately no matter what.
Put the fuse back in and it won't.Only Rubicons will start with the clutch out in 4L.
On a steep hill, you don't have to push the clutch in and smoke the clutch, roll back, spin the tires to get started if you can just crank it up in gear and go.I was going to ask WTF were they thinking in regards to Jeep allowing the Rubicon to do that. Maybe it's OK because the Rubicon 4lo ratio is so low that the engine will easily turn over and when the engine gets to running the chances of the Jeep quickly leaping onto something or someone is pretty slim to none. I am kinda surprised the lawyers wouldn't put a stop to this immediately no matter what.
One thing has nothing to do with the other.On a steep hill, you don't have to push the clutch in and smoke the clutch, roll back, spin the tires to get started if you can just crank it up in gear and go.
I've never moved a fuse and I bought it brand new. So, there's a way to prevent a Rubi from starting with the clutch out in 4L?Put the fuse back in and it won't.
Does for me, steep hill, just turn key off, stop. Turn key to start, go. No clutch smell, tire spin, or rolling back.One thing has nothing to do with the other.
Sometimes that's easier said than done.On a steep hill, you don't have to push the clutch in and smoke the clutch, roll back, spin the tires to get started if you can just crank it up in gear and go.
I didn't say there was or wasn't.There's no fuse in an 06 Rubicon...
mrblaine and theboogieman indicated I had moved a fuse. I drove it off the lot brand new with 4 mi on it, and it's always started in 4L without pushing in the clutch.I didn't say there was or wasn't.
