Need verification on 05 engine wiring harness
Coalcracker18
PA
I picked up an engine today that still has the wiring harness on it, the engine is from an 05 automatic my Jeep is an 05 6 spd. At a glance I noticed that mine has the white plug that goes to the ecu and the donor engine has the green plug on the harness. I'm assuming I will need to swap the harness to make it work on mine is this correct? I know the earlier years were interchangeable I'm not sure of the late models.
2005 and 2006 have an integrated TCM into the ECM. This makes it a PCM. I believe you need your harness from the manual.
