There goes another one of my ideas... LOL
https://www.tmrcustoms.com/collections/tools/products/diy-toe-alignment-tool
Am I missing something? Looks like a 2” or larger piece of angle iron with holes drilled in it would do the same thing for way less money.
I just know that at 75-80MPH, with 33x11.5 Nitto tires, my TJ was driving pretty darn comfortably after I did my 1st alignment job on it a couple of days ago. 😋Yes, that will work. Need two, clamp them to your rotors. But they had better be perfectly straight, we're measuring to within about 1/32". It's surprising how much warp a brand new angle or square tube can have.
Length of tool also determines what measurements are needed (front & rear) to get the proper angle.
Yes, at 24" it's 1/8" difference, but I like 35.75" where 3/16" difference is correct.
OK stupid question here.
What actually causes miss alignment to happen? Metal stretch, bolts shifting, bending components or just wear? I can see needing to do an alignment after doing work on the front end components.
See post #10 above.My only questions is if the toe-in should be different than the standard 1/16- 1/8", which I have been measuring at the tire diameter. These tools seem to all be about 24", so is the toe-in still 1/16- 1/8"?
See post #10 above.
How are you going to use a 24" tool without removing the tires?
It can be done, but you need a set of 36" tools with accurate standoffs from the wheels. I haven't seen any for sale. Making your own would require some pretty good precision.
Some people lay their 36" square tube across the tires, but measuring against air-filled flexy rubber bladders with bumpy surfaces just seems nuts to me. Even measuring to a point on the tread can't be terribly accurate or repeatable.
