Yes that guy has done some amazing things for Prosthetics.
Sucks to hear it's shut down, that's got to be a bummer. Hopefully you can kill some time on your TJ or your daughters TJ in the meantime.
Hope all goes well and it’s the best replacement foot you’ve ever had.
Nice! I didn't realize it was such a pain in the ass to swap the accessories, I thought a quick-change type thing would have been the norm by now. Hope it works well for you!
Sure, understood. I have a buddy that lost his lower leg when a sling broke when installing a crane. I think he’s had a Bluetooth leg for about 10 years. Cool technology and it’s getting better.This isn't a replacement foot for me right now. I'm involved with a foot study thru the VA where they are trying to build a computer program where they could emulate differnet types of feet so that a person could come into the clinic and instead of having to try different feet which can be very expensive this computer program would allow you to try out a bunch of different during one visit becasue the computer can change the foot by a keyboard stroke.
Had a neighbor who lost his lower leg as a child too, mower accident. He designs prosthetics now.
Yeah my buddy has had issues with his hip on the side with the full leg due to compensating while walking on the prosthetic. It’s a fine line to balance.While I was at the VA yesterday the research team also told me that there is going to be another study happening in the next few years where they are going to be doing a study of feet that help to compensate for uneven ground.
If you are standing on a side hill your ankle compensates for that angle by leaning uphill. Or stepping on a branch or rock where you roll your ankle to one side of the other. But with these prosthetic feet the only side to side flex you get right now is when the blade that is the sole of the foot is split.
See how this is split down the middle? It is what allows your leg to lean left or right. To the best of my knowledge they don't make a prosthetic foot that can pivot in all directions. With that split your get a few degrees of lean but it isn't anything like a natural ankle. Just like my normal foot I have it has 27* of front to back angle/motion. That isn't close to what your ankle moves BUT it's way better that some of these feet that are fixed.
I think you and I have talked about this before. I trialed a foot that was powered and I could connect to it with my phone. I didn't like it because it weighed almost 9 lbs and trying to walk with that weight swinging at the bottom of your leg took a lot more energy. Plus the foot I was trying could not get wet and it wasn't rated to handle large amounts of weight. So trying to pickup a 100 lb tire & wheel could break it. And then the batteries only lasted 3-4 hours.
They say that it takes approximately 30-50% more energy to walk for each joint you have lost. So by making a prosthetic lighter it makes it easier to walk, And it is also why they try to design it to store energy as you walk so it can help to push off as you walk.
That's a sweet setup! Maybe fab up something like this for CC?need to do a setup like this....... Carry a small 9mm or .380 as adding more weight sucks down low.
What do you mean by storing energy? Like spring steel that helps you bounce off the weight of a step or what?So I have had this test foot now for a week an a half so I thought I would share some observations with everyone. For a daily wear foot it is a good fit and because it stores energy as you walk and then pushes off as you step forward it means that you don't expend as much energy as you do with a foot that doesn't store the energy. The things I don't like about it is when walking over uneven ground. Because it doesn't have any articulation if you step into a hole of other spot it throws you leg around and really tweaks my knee.
I have to go back to the VA next Wednesday to return this foot and to get the next one in this study. But I warned them that if the idiots in Seattle were acting up after the elections I might not come. I'm not going to risk going over there and get caught in a riot or them blocking the freeways. I can guaranty one thing. I'm not going over there with out protection. So as long as the world doesn't end next week I'll be posting on the 4th about my next test foot.
Yes it's just like a spring so as you walk and place your weight onto the foot the curved shape compresses and then as you are stepping forward it pushes off giving you an assist to swing your leg forward.What do you mean by storing energy? Like spring steel that helps you bounce off the weight of a step or what?
That's cool, apparently I've taken my feet for granted over a lifetime of walking & I'm going to have a whole other level of appreciation for them this morning on my run. I'm glad there are engineers out there putting effort into stuff like this.Yes it's just like a spring so as you walk and place your weight onto the foot the curved shape compresses and then as you are stepping forward it pushes off giving you an assist to swing your leg forward.
The foot in this video isn't the foot I have but it explains how it works.
