Welcome aboard and back to the Jeep life / obsession! Any chance you can post what you've got in terms of lift and wheel size, etc? Really digging the overall stance of your TJ! Thank you in advance.
Sorry I had to find my file
My Jeep specifics
VIN ————————————-
Interior Color: Grey
Transmission: 32rh, 3spd, 23 spline output
Body Type: Sport Utility (wagon)
Sub Model: 2dr Sport
Exterior Color: Citron Green
Year: 1997
Mileage: 117,323
Make: Jeep
Model: Wrangler
Trim: 2dr Sport
Engine: Hesco 4.7L Stroker Engine
Power Options: steering, brakes
Fuel Type: Gasoline
Rims and Tires
Method Race NV Wheels 17inch
w/ wheel adapters 4.5 to 5.5 (my old truck rims)
Hankook DynaPro MT RT03
LT315/70R17
Mechanical:
19-gallon fuel tank third pump change
4.56 axle ratio
ARB front and rear Spartan Locker
231J transfer case with Advance Adapters NP231 SYE
Dana 30 Inner Axle Sleeve Kit
Front JKS sway bar disconnects
Low-pressure BDS gas-charged shocks
V8 Durango Pwr steering box swap
ABB, RC, roughcountrySkid plates transfer case, none on fuel tank
Tools-inc: high lift jack
1998 ZJ V8 steering bars and links
70mm throttle body
Spectre Performance 9050 Air Intake Kit
Tom Wood CV Driveshafts front/rear
Mopar Dana 44 rear axle with Disc brakes
850-CCA AGM maintenance free battery
160-amp alternator from 2000 1500 Dodge Ram 5.7L slide bushing to fit TJ,
Front YJ brake lines they are longer,
Rear Rough country extended stainless steel braided brake lines
Pwr front disc/rear 98 ZJ disc brakes with adj proportioning valve
Rusty's TJ Wrangler 4.5" Long Travel Kit with 1.5 pucks to level
Door gas cap mod
Flo-master muffler w/ turn down after axle
Exterior:
Savvy Aluminum TJ Full Corner Armor
XRC Armor - Front Tube with 3" Flare (will be replaced soon)
XRC Armor - Rear Tube with 3" Flare
Savvy Billet Aluminum Tail Light Kit
Rockhard Rear Bumper w/ Spare Tire Mount (does not rattle)
XRC frame mounted side armor
JCR based Mauler Stubby /w custom hoop
Best top replacement soft-top
4 d-rings w/ Bubba Rope in back
Moved washer nozzles to wipers (from a Buick)
Full metal doors w/locks
Halogen headlamps
Variable intermittent windshield wipers
52" LED curved light bar (they all whistle)
Rugged Ridge 8500lbs winch
Homemade black swing away exterior mirrors
LED fog lamps
Warrior Products 2370 Spare Tire License Plate Mount
Interior:
Rock Hard bolt -n roll cage
(2) carpeted front floor mats
Auxiliary 12-volt pwr outlet
In-dash CB Radio installed in upper dash vents
Fixed antenna
Glove box w/lock
Rear seat/wheelhouse/cargo area 10oz carpeting
Removable front seat area carpeting
Dirtydog4x4 rear netting It covers the rear seat and sides.
2-spoke leather wrapped steering wheel
Cargo tie down loops
Digital media receiver (does not play CDs) stereo radio (4) speakers, padded sound bar
Full-length floor console w/storage, (2) cupholders
Lamps-inc: courtesy, engine compartment
Removable fold & tumble rear seat
Sport bar w/full padding
Tilt steering column
