Hey all, been on here without a profile for quite some time. Finally decided to join so I can post stuff.. on my second TJ. First one was a 2002 Wrangler X Apex Edition with the 4.0 and 5spd. Had it for a few weeks before it was totalled.. then I got married and was told I'd never have a Jeep again.. fast forward to a few weeks post divorce ans I have another 2002 Wrangler Sport (also 4.0L / 5spd). When I got it, it was the Chameleon, then the colorshift wrap can off and it started breaking down.. either it was broke or I was broke, so it became ALWZBRK.. Then I tried removing that curse and named it TRN2LA after the Cobalt Tarantula... at that stage it was equipped with:
2" OME Springs
1.5" body lift
35x12.5R15 Mickey Thompson Deegen 38s
15x8 Pro Comp Series 31
4.56 Gears w/ Front Spartan Dana 30 and Rear Eaton Elocker Dana 44
Poison Spyder BFH Brawler front bumper
Smittybilt XRC rear bumper/tire carrier
AirAid Throttle Body Spacer
DIY Snorkel
Banks Monster Exhaust.
Sept 11th last year it blew a radiator hose and started an electrical fire under the hood. It has since earned the title Spitfire. I will model it after the Supermarine Spitfire aircraft.. It is currently sitting in TX, where I will be moving shortly and rebuilding it.. I am planning on doing as much of the build as I can in my garage. Went to scool for Automotive, so I have some knowledge, but will be asking questions as I go. I know this forum has tons of people that have done thier own builds and may be able to help guide me in a better direction.. the goal build list is:
4.6 Stroker (8.8:1 compression w/ forged internals)
Banks Torque tube headers
62mm Throttle Body
DIY Turbo kit w/ Holset H1C hooked up to RedRock4x4 Snorkel
Chevy 700R4 4spd auto
241J t-case (eventually swap to atlas)
Ford SD tons (Dana 60/10.5) geared to 4.88 with Yukon Zip Lockers
6+ inches of total stretch with 4" springs (may go coilovers.. idk) Triangulated rear, 3 link front. (may add more)
40" Mickey Thompson tires
Highline front fenders, Boatsides and Rear Comp Cut.
Custom Bedliner Paint Job
Anyways, here's the first Jeep and the current jeep in its many phases..
2" OME Springs
1.5" body lift
DIY Snorkel
62mm Throttle Body
