New Crown passenger front axle and new Timken hub bearing. The hub will engage and go on maybe a 1/2” but then stops. I used a rubber mallet but don’t want to get it jammed on there and not get it off. The old stub slides in no problem.
Do I have a bad axle? Or is it normally tight? Had no problems with the drivers side but I didn’t replace that axle, just the hub. Reason I replaced the passenger side is because I dorked up an ear pressing out the U Joint.
I know, I know…. But it worked so well on the drivers side.
Any help is much appreciated.
