New to me 2002 SE. Stock except for 2 inch leveling in the front. Great forum ! Have been reading and learning for several weeks..... tons of great info.
Chris,
Yes the underside is pretty clean.... no frame rust just some surface stuff on the axles that should brush up and clean up nicely. Only plans now are to work through the systems. Already changed oil and filter, serviced the differentials, greased the front end, complete brake job on the rear brakes. Still have valve cover gasket to try to dry up the topside leak and the rear pinion seal looks like its seeping a bit!
Having a blast doing these small jobs and getting lots of good info on this forum
