New to this website
Rurys
Rurys
27
cali
Thank you guys well my little baby it’s a 2002 4.6 stroker it has a 3 inch Suspension lift and it rides on 15x10inch well rims for tires it has 15x12.5 km2 tires,it rides on 4.88 gears with lockers,however it sits a little sick right know I believe it is the ECMs I have no spark my cam sensor shorted out and I do believe it shorted my ecu.
Thanks again for the welcome.
Reactions: skrelnik
Rurys
Rurys
27
cali
skrelnik
1,177
CT, United States
Welcome aboard...looks like you have a 2nd TJ in the background.l, what's up with that one.
What front fenders are you wearing, like the looks and the extra space for tire clearance.
Reactions: Rurys
Rurys
Rurys
27
cali
Yes the green Tj is a 1998 stick 4 cylinder Tj that one is been sitting in the garage for the past year it sits on 15x 10 Alcoa’s
indio
129
Chicagoland
Welcome. This site is such a great resource. People have been very helpful to this new TJ owner, even when I was wigging out about an oil cap that wouldn't unscrew. :)
Nice TJ - red is my fav. By the way, looks like your hood latches are missing the lower pieces? What is holding down your hood? Are those bumps further up some kind of alternate hood latch pins - like some race cars used to have?
Also your TJ looks a tad higher than mine. But maybe my 3" lift has sagged, or your front fenders give a higher appearance.
Reactions: Rurys
Rurys
Rurys
27
cali
up date. I guess she is getting a little better, now she breathes again it turned out it was the dizzy, the gears that mesh to the cam gear were worned out . I am steal getting P0340 and P1391the dsi dizzy came with a new cam sensor so I do believe its just a matter of turning the dizzy closest to zero degrees timing. I did lined up the number one piston on tdc with the mark on the crank shaft pulley
