New to TJs and off roading, need suspension knowledge
ls1_sounds
2
Marysville, WA
Hi, I'm new to Jeeps and off-roading but have been reading and learning on the forum for a while. I used to race cars on-road and am mechanically inclined, but have a big 4x4 learning curve ahead of me. I recently bought a 2001 TJ with 118k miles, 4.0L and 5-speed, Rough Country 3.5" lift kit with Bilstein 5100s, Dana 44 rear with Detroit posi and 30 front (no lockers), 4.88 gears, 35" Goodyear tires, front Anti-Rock, and some kind of fender flares I haven't ID'd yet (maybe Smittybilt). I already fixed a couple of things including a bump steer issue by replacing the drop Pitman arm with a stocker so it's now fun to drive. It does ride really rough but that seems common with RC lifts, so I'm at 20psi to help with that. It still has vague steering and definitely needs a track bar, but there's no death wobble. I plan to start by upgrading the steering, then the suspension, one area at a time until I get it where I want it.
What is the best order to approach the upgrades? Shocks first, then springs, or something else? It's a weekend toy so I am mostly looking for off-road capabilities for trail riding and ORV parks in the Pacific Northwest. I do still want it to ride and steer well on the road so my wife or daughters can drive it on the freeway and we are comfortable driving it to the fun areas. I like the idea of a lower CG build so I'm thinking 3.5" - 4" of lift and then highline fenders or whatever is needed to prevent rubbing. I will probably stick with the 35" tires. I like what I'm reading so far about Savvy, Currie, and Metalcloak but haven't picked a route yet. I don't mind investing money in quality parts, but am not sure yet how to go about getting the best performance and I need your advice.
Thanks for the help!
-Chad
Reactions: Squatch
Rob5589
Certified video trained differential rebuilder
6,368
W Sacramento, Kalifornia
Welcome to the forum. If it needs a trackbar that should come first.
Ride is mostly determined by shocks. Many of us run the Rancho 5000X with great results.
Steering can be upgraded by performing a V8 ZJ set up or a Curry steering set up. Budget will point you in the right direction.
Adjustable control arms can get your caster within spec after lifting. Too little caster can cause issues as can too much. You will have to see if yours are adjustable or not and whether or not the alignment is within spec.
Reactions: tomtaylz
MutantNinjaTJ
250
The sewers of Newer Mexico!
Currie steering set up because of the 35's, front adjustable control arms to get you caster back and that will help with the "vague" steering feeling, and toss the Bilstein's and put on a set of Rancho RS 5000X shocks. Ranchos run a bit long so do the math and make sure they fit.
Fouledplugs
2,828
Alabama/South Carolina
-Chad
You could tuck the skid via “tummytuck” with 4 inch springs and 1.25inch body lift which would be needed for the tummy tuck anyway. UCF makes some great tummy tuck skids as well as Savvy.
Tummy tucking will get you a step in the right direction for keeping it low on 35’s. Hi-lines would also help here. But IMO, the skid should be addressed at 33 inch tires or more.
A motor mount lift will also help keeping that low cog you are shooting for and compliment the tummy tuck.
A little more help would be accomplished by a bit of a stretch. Most owners wont bother, because it is such a project. But 35’s on the short 93inch TJ wheelbase is a bit silly to me. Thats just my .02
Im assuming it already has an SYE and DC driveshaft? Its not mentioned, just curious.
Reactions: MutantNinjaTJ
L
ls1_sounds
2
Marysville, WA
Wow, thank you guys for all of the info and recommendations! It sounds like I need to hit the trackbar, steering upgrades, and shocks first, probably in that order. I need to check the caster still and learn how to check camber, I haven't aligned it yet other than centering the steering wheel. There is a lot of play in the steering right now though.
Is the Currie steering system worth the extra coin over the V8 ZJ setup? I need to learn more about their differences.
I haven't heard of tummy-tucking yet so I'll check that out along with the motor mount lift. It does have an SYE and I noticed it had a Spicer driveshaft sticker but I'm not sure what a DC driveshaft is. The U-joints look new but I'm not sure if they are stock or stronger.
Alex01
Enthusiast
2,654
Martinez, CA, USA
If money isn't an issue I would stick with the currie setup. If you have an SYE you have a DC driveshaft.
Any photos of the jeep??
Here is a DC driveshaft.
103921
Reactions: MallCrawlOnTons
astjp2
2,330
Utah and Alaska
With the questions you are asking, you need to read some more, post some pictures of your jeep and digest what you are learning. You also need to decide what you will do with the jeep, mall crawler (wife), rocks, mud, etc. There are so many options for different types of terrain where you are at, that it makes it a challenge to set up for all of them. I try to set up for the most likely terrain that I have near me, which is desert with some rock crawling. I am going with selectable lockers, 4" suspension and 1.25" body lift. I installed custom control arms that use synergy DDB's by Core 4x4, adjustable track bars and YJ brake lines. I still have a few things to work out like a bad transmission and I am going to upgrade my jeep to front and rear dana 44's, probably install a 4.6 stroker motor, and a few other modifications. I am out for a nice ride, so I have 12" stroke fox shocks and the brackets to outboard them. So pick your poison and good luck.
Reactions: Alex01
Honeybadger
44
SoCal
Luckily you have a rear Dana 44, building that up from scratch gets pricey. A very weak link for 35’s is the D30 front axle. Once you get the steering fixed up you may want to look @ chromoly axle shafts. Other than that I would go do some wheeling and see what you like to do and build from there.
MallCrawlOnTons
515
West Georgia
Not trying to put you on blast dawg. Looking at your profile and posts, you got a stock wrangler. Were do you come up with all these recommendations for mods?
Reactions: Jerry Bransford
Squatch
Master Thread Derailer
4,807
Everett, Wash, United States
-Chad
Welcome to the forum. I'm just south of you, on the other side of the flats, in north Everett. You're going to dig on all the information that flows through these "pages"!!! Folks on here love 'em some pictures, so how 'bout it? ;)
Westtown Willy
714
West Chester, PA, USA
I would recommend the Currie steering if you are going to 35’s, Amazon had it for $476 not too long ago, damn good price. Wait till it shows up on your porch, you’ll see why it comes highly recommended.
what ever could you be talking about 😁
Beautiful, that is the epitome of a Jeep right there, primarily stock in appearance with just the right extras – nice fat wheels with appropriate lift, tight & functional front bumper & no extraneous blingshit, no doubt a ton of dough tucked away underneath where it can’t be seen but sure can be experienced where it counts, great job man, trying to push towards that.
Fouledplugs
2,828
Second time you have asked and the same person liked it IIRC.
I asked a male doctor who specialized in pregnancy and giving birth how he could be good at something he had never experienced being that he was male. How could he recommend any advice for a pregnant woman.
Nice potential question to alot of folks who replied in your, “Anyone have a RockCrawler,” thread. I might have been the only one who drives a YJ daily and beyond that posted my trip Pics in the SOA YJ on 38’s.
Yes, one of my Jeeps is mainly stock. Still doesnt mean I dont know about bolt ons for TJ’s.
I learn about mods and upgrading the stock suspension the same way a lot of others do. As an example, I dont need to buy Rough Country shocks to validate my understanding that they ride rough and there are better options to select for the TJ/LJ
Reactions: ranger101
MallCrawlOnTons
515
West Georgia
Yea he gains knowledge slowly with real world experience.
Yea I’ve seen you have the stock yj. thats cool bit doesn’t answer any question I asked in that thread. I didn’t see any pics of your yj on 38s either? It appeared your yj is on 31s.
2 of your jeeps are mainly stock you mean?
So just via reading? No experience with the mods you are recommending?
Fouledplugs
2,828
Actually 3 of them are. I’d rather not argue with you or have you validate my experience and knowledge. Nor would I like to divulge info about everything I own. It’s not important and proves nothing.
If my post are wrong, leave you with questions, or without fact please do chime in. Please tell me I am wrong, you disagree, and share your justification/facts. Im open to other opinions/ideas.
Or just keep gatekeeping. If you would rather gatekeep, gatekeep everyone rather than single me out.
Reactions: jodomcfrodo
MallCrawlOnTons
515
West Georgia
3 stock jeeps and you on here giving advice on which products are better than others? Hmm okay.
Some of your posts aren’t “facts”. They are opinions with no experience.
And don’t get all butthurt cause I called you out on your post recommending products you’ve only read about.
And According to your tjs milage in your “build” thread Im guessing you have the least experience behind a tj on this whole forum.
