I will be installing a Smittty built x20 10,000 winch on my 2004 TJ. Is there anything I need to be concerned about as far as battery and altenator size? I currently have a 550 cca battery and the stock 115 amp alt. thanks for any help.
Watch a few saftey videos. Make sure to tie your line off low on trees so there is less leverage and also be aware heavy rocks may not be as heavy as you thought once the jeep is on the other side of the line.I will be installing a Smittty built x20 10,000 winch on my 2004 TJ. Is there anything I need to be concerned about as far as battery and altenator size? I currently have a 550 cca battery and the stock 115 amp alt. thanks for any help.
Start with a 750 cca battery and make sure you make good connections. Helps with winter starting too.I will be installing a Smittty built x20 10,000 winch on my 2004 TJ. Is there anything I need to be concerned about as far as battery and altenator size? I currently have a 550 cca battery and the stock 115 amp alt. thanks for any help.
So the answer to your question is yes and no. Yes increasing engine RPMs will increase the alternators output. But most 12 volt DC winches depending on load can draw upwards of 550 amps. Take the M8 for example, at no load it draws 80 amps and at full pull 435 (keep in mind these are ideal numbers created in a lab). Most TJ alternators put out in the low 100s so you really are just relying on the capacity of the battery to run the winch. So even at half rated load on the M8 you are still using more amps than the alternator can supply. Biggest reason to keep an eye on the volt meter is the TJs PCM really starts acting weird once you drop below 11.5 volts.If you're winching and you notice the voltage drop, can you just give it a little gas to keep up the volts?
The situation I have in mind is pulling of a stubborn shrug or small tree. I'll usually sit inside with my foot on the brake in neutral and give it some gas when the volts drop.
Ok, now we open Pandora’s box. Lol@Blackjack Good Stuff, thank you.
Ive seen the voltage light before, and just paused for a minute. I had no idea it would be bad for the pcm or the winch. Looks like I’ll have to upgrade the battery and take my time before the next landscaping project.
Just get yourself a decent quality AGM battery, and there is absolutely no reason to go with dual batteries. And most winching needs are completed in 30-45 seconds so rarely do they drain the battery enough to worry about, especially when the engine is kept running. I've even winched myself off the trail at least twice without the engine running and with just one AGM battery. Nope, doing that did not drain the battery... the engine started right up after fixing the engine issue.@Blackjack Good Stuff, thank you.
Never hurts to have enough amperage to run the DC vertical mill I know you have tucked away in there somewhere.To further Jerry's comments, NO OPTIMAS. I think I had the last two decent optimas, way back. The AGM's can also be mounted in any position, adding to the versatility. I use two batts not really for winching but for welding. I can connect both batts together to make 24v.
Hi @Jerry Bransford - i decided to listen to your advice and stick to factory alternator on TJ Sport 4.0 2004. Decided to invest into quality battery and found this Odissey AGM - https://www.odysseybattery.com/products/odx-agm34-battery-34-pc1500t/Just get yourself a decent quality AGM battery, and there is absolutely no reason to go with dual batteries. And most winching needs are completed in 30-45 seconds so rarely do they drain the battery enough to worry about, especially when the engine is kept running. I've even winched myself off the trail at least twice without the engine running and with just one AGM battery. Nope, doing that did not drain the battery... the engine started right up after fixing the engine issue.
And when doing repetitive pulls, which are rare, just use a little common sense battery management. Just give the alternator a chance to recharge the battery some between pulls and keep the rpms up so the alternator can put more power out.
AGM batteries work better for offroading since they are constructed more ruggedly to resist the shock and vibration of offroading, and they are usually able to provide more current and charge more quickly due to their low internal electrical resistance. If you have the $$$ it's hard to beat Odyssey, Northstar, or Bosch Platinum AGM batteries. If not, most store brand AGM batteries hold up fine.
Do avoid Optima batteries, their quality and lifespan went to hell after they were purchased by Johnson Controls who immediately moved their entire manufacturing line to Mexico. That's when they started using cheaper materials and also stopped using pure lead.
The main reason to run an AGM of any sort is to get away from liquid acid. You aren't doing that by carrying one in the back.I can carry my standard battery from Autozone, as a spare in a back, as a back up.
