Hey all,
First, big thanks to this community for all the help you have provided so far. For those that haven't seen my previous posts, I bought a wrecked TJ and essentially built a new one from scratch using the drivetrain/interior/wiring/some body parts from one, frame from another, tub from another, axles from another, and so on. I'm down to the last couple issues to fix, but the Jeep runs and drives amazing.
The biggest issue I'm chasing is the No Bus issue that we all hate dealing with. The issue started right away after assembling the "new" Jeep. It went away a few times and all my gauges worked when I drove. Was working kind of consistently. Then one day they stopped and haven't come back. The only thing that happens right now is the oil pressure gauge climbs ever so slightly when I turn the key on. Nothing else works. I have tried many fixes so far, as I will list below:
- Started simple with cleaning the connections at the instrument cluster. Bent the pins a little bit to promote a better connection. Dielectric grease. No luck.
- Tested the continuity of the twisted pair of wires that feed from the PCM to the cluster (can't recall the colors, I think a violet wire and a white/black). They have continuity.
- Tested for ground at the two ground wires at the PCM (A31 and A32 in the black connector). I have continuity and no resistance.
- Tested for 5v (with key on) coming from A17 in the black connector and B31 in the white connector. I have readings of 5.17v and 5.21v respectively.
- Tested for 12v power at A2 and A22 in the black connectors at the PCM. I have 12+ volts at each.
I don't think the 5v sensors would be an issue because I don't have a no start issue in combination with the No Bus, but I was already digging in there so why not?
So from what I'm understanding, I have power to the PCM, proper grounds at the PCM, unbroken wiring to the instrument cluster, and what should be clean connections at the cluster (this could still be an issue. From what I've seen, this is often the problem, but I have done all I can to clean that up).
Where do I go from here? Is it likely the PCM is sending a bad signal to the instrument cluster? Is the cluster receiving a good signal (as evidenced by the oil pressure gauge moving a little bit) but isn't always functioning correctly? Both of these are expensive fixes, and I don't want to take guesses and spend money I don't need to.
Thanks y'all!
Thanks y'all!
