Long story short, on an 05 TJ 4.0 a/t, no crank with key, crank but no start if jumping the solenoid. No reverse lights. Ignition actuator OK. Transmission Range Sensor was the likely suspect, but before opening up transmission, I tried putting a fuse in #20 (which I guess works on a manual with a bad neutral safety/clutch switch). That didn't work, but #19 was also empty and for some reason putting a fuse in it did the trick. I can't find anything in the forums or the service manual that would explain this. Anyone?
