Not that I really need a heater now but mine is Luke warm. Good flow with both hoses hot and blend door is closing what am I missing? Do a reverse flush? 98 TJ Sport.
Core is a great possibility but less probable if both hoses are the same exact temp. It is a very easy piece to eliminate just by doing a flush of it with a garden hose.Yeah... Water pump or possibly a clogged heater core maybe.
So was it the air in system or the low coolant level? Hmmm
Thanks I will check level. How do you get rid of air in the system if that is the case. Where did the air come from? Water pump replacement perhaps. I ran the heater and such when refilling radiator after pump replacement.
My 93 Cherokee quit throwing heat last winter and it was low on coolant. The recovery tank was full, so I never checked the radiator. The radiator itself was almost a gallon low. The same time I added coolant to the radiator I replaced the cap with a new one, and had good heat.
