TRE all day...
I have their soft shackles and their 6’ orange tree/rock shackle as well. Big fan!
What is used for a soft recovery point if not using steel shackles or a hitch receiver/pin?
Side question. What do you use to connect two recovery straps? Can a soft shackle take the impact load?
Yes.Side question. What do you use to connect two recovery straps? Can a soft shackle take the impact load?
As long as you get a dog bone in there, you can get them apart again. If you don't, you now have one longer strap.If both straps are loops at the end, growing up we would just slip each end through the other’s loop and not connect them with anything extra.
Like most things, they have a fair amount of bullshit associated with them.kind of a tangent but has to do with recovery.
anybody seen or use the pulley puck? these are super light and supposedly do not damage the synth lines.
https://www.customsplice.com/products/diamond-recovery-ring
It did the intended job under well designed conditions on the ones I've seen, but the ring doesn't turn and under high loads, that isn't really good for the rope.yes i've seen them/it used on video. it did do the intended job with no damage to the anchor loop or the winch line.
it would never be the only device carried but, would offer a lightweight option and/or back-up.
your point of the disk requiring a babysitter is accurate you cannot slack that line with this device.
what/who are yall trusting for snatch blocks. (somehow i have the feeing i asked this b4, CRS )
Figure out the weight ratings yet?yes i've seen them/it used on video. it did do the intended job with no damage to the anchor loop or the winch line.
I'm going to make them and start selling them with a 1 million pound rating. 1 million in italics with a footnote that says "try and break it, I dare you".ha. IDK, i agree it's kinda odd, the shape is the strength. you could make them out of dense plastic.
lessor pull angles can result in smaller contact patches, maybe that plays into it.
but more likely marketing, most don't wanna see S, M, L, they want the #'s. and BS is good enough.
i have not seen/found a dead pull until failure test S vs M vs L. it'd take a bulldozer and steel cable to crush 1 i bet.
in our case line failure should occur 1st.
and yes your again correct the ring does/can/ will have some dead spots or stalls while in use under load. but then would act similar to our hawse while stalled.
and who's Ricky? i know maybe 3 of these guys by 1st name.
