I have a 2006 wrangler. I went to start it and nothing. Lights work, wipers work but no turn signal, no dash lights and it won’t start. I checked fuses and a single power wire to the ignition switch. I’m at a lose
Easy stuff first: make sure your batter cables are clean & secure to the posts, and make sure your shifter is actually in park. Next would be to check & clean the ground wire that goes from the battery negative to the engine block. Those tips right there fix a lot of odd issues.
