No power to blower or fuses
kellydog
2002 Wrangler Sport
Houston
2002 - Blower problems. Just bought this for my wife. Trying to get it into shape. Blower does not work. Fried connector to blower and bad blower (locked up). Replaced the blower, connector and have a relay on order (not sure if it is bad). Tested fuse 8 and no power. Tested fuse 1 in the power distribution center and no power there either.
kellydog
kellydog
2002 Wrangler Sport
Houston
Yes. I have tried it with the ignition set to on and with the engine running.
Chris
Administrator
Staff Member
Salem, Oregon
Download a free copy of the FSM here: Jeep Wrangler TJ Factory Service Manuals (FSM) & Technical Documentation
Once you do that, you can go through the wiring diagrams in the back and trace the wires until you find power.
I had a similar issue on my XJ which took me months to solve. Come to find the wire was getting power before it entered the fuse junction block, but it wasn't getting power on the other end. It wasn't a bad fuse, it was a bad wiring connection believe it or not!
CharlesHS
Carmel Mountain
IF fuse 8 has no power; what about 5,6, &7 ?
Sounds like you may need to disconnect the fuse block and check the wiring beneath.
According to the FSM.... 8W-10-13; the other 3 fuses are on the same fuse block.
I noticed you said that fuse 1 also doesn't have power; do fuses 2 & 3 on the PDC have power?
The only wiring upstream of that is the fusible link and the power from the battery according to 8W-10-9.
You may also need to unbolt the PDC and check its wiring.
kellydog
kellydog
2002 Wrangler Sport
Houston
Nope! 5, 6 & 7 show no power with the ignition on.
What is that telling me?
CharlesHS
Carmel Mountain
Fuses 5,6, & 7 are fed off the same fuse block and since fuse #1 from the PDC is also without power; then I would start trouble shooting beneath the PDC.
Do fuses #2 & 3 on the PDC have power ?
If they don't.... then there is a definite problem with the PDC bus.
The only wiring upstream of that is the fusible link and the power from the battery according to FSM 8W-10-9.
kellydog
kellydog
2002 Wrangler Sport
Houston
Thanks. I will check fuses 2&3.
I have no experience with the PDC but assume if I disconnect the battery, I can’t hurt anything?
CharlesHS
Carmel Mountain
Originally you said that fuse #1 in the PDC was dead.... Something change ?
Fuse #1 in the PDC goes thru a couple harnesses (C170 Red/LtBlu and C205 Red/Lt Blu) to the Blower Motor relay.
Check Pin 4 for the Blower Relay plug to see if you have power.
Blower Motor relay connector Pin 1 Dark Green wire will go to the blower motor
kellydog
kellydog
2002 Wrangler Sport
Houston
Sorry Charles. When I said Fuse # 1 I was referring to the PDC fuse.
I am looking at the relay drawing but do not see the identifying number. I see 30, 85, 86, 87 and 87A. So I test with the Le on the on position or with the engine running?
kellydog
kellydog
2002 Wrangler Sport
Houston
Sorry, I completely misread your note. I checked the fuse board under the glove box, not the PDC as you instructed.
Let me check the PDS 1&2. (Sorry)
CharlesHS
Carmel Mountain
The pins I refer to are the factory numbered slots, not the relay numbers.
You can test these with the ignition switch to ON; the engine does not need to be running.
If you have power to PDC fuse #1 then follow my previous troubleshooting instructions in Post 12.
kellydog
kellydog
2002 Wrangler Sport
Houston
OK, I do have power to PDC position #1. I must have had a bad ground on a previous test.
I cannot locate position #4 on the blower relay connector. I did test all of the positions and the one in the top middle position was live.
CharlesHS
Carmel Mountain
As an interim test.... remove the horn relay and place it in the blower fan relay position and turn the blower fan switch on and see if the relay clicks energizing the new fan motor....
Pin 4 is from the PDC and Pin 5 is relay activating power from the climate system.
This will test whether there is power from the PDC and relay activating power.
kellydog
kellydog
2002 Wrangler Sport
Houston
I have a new relay supposedly showing up today. UPS shows in transit. So what is fuse#8 on the fuse block behind the glove box connected to? Is that connected to one of the relay pins? That shows no power (even when the relay was plugged in).
CharlesHS
Carmel Mountain
Fuse 8 in the fuse block behind the glove compartment goes to the climate control console and ties into harness connector C205 going to the blower motor relay.
