I flat tow my 1999 4.0 to and from work, and like everything recommends, i disconnect the battery when doing so. Usually I get the normal rough idle for 10 minutes or so afterwards, a couple of times I've had issues with it reading the chip in my key, but after a few tries it comes to life, this time I have nothing, turns over fine but won't start. Seems like the pcm has been whipped clean or something. I haven't had time to check things with a voltmeter, but I did try to jump it off upon arrival in case voltage was low, and trickle charged it all night and the battery is holding a good charge (optima yellowtop) the fuel pump isn't priming or anything on it, and it was running fine when I hooked it up to tow. I won't ever disconnect the battery again, I'll just hook it up with a charge wire, but any help getting it running again would be greatly appreciated.
