My thoughts exactly and JB and I talked about that.Time to add a in cab switch so you can have some redundancy.
What psi were you running?
He was running 18 psi.Time to add a in cab switch so you can have some redundancy.
Jim its better then mine though. I only used it once to spool and my motor was dead the text time I needed to tighten the slack after changing mounts. The in cab i did from 12voltguy was really easy. I think he lives in your neck of the woods.
I also used the 12voltguy years ago when I put my in cab winch control inside my first Suzuki Samurai. Pretty easy to install.Jim its better then mine though. I only used it once to spool and my motor was dead the text time I needed to tighten the slack after changing mounts. The in cab i did from 12voltguy was really easy. I think he lives in your neck of the woods.
I have nothing but good things to say about him.I also used the 12voltguy years ago when in put my in cab winch control inside my first Suzuki Samurai. Pretty easy to install.
ROTM 2019?
Good idea, was thinking the same thing, but used a snow scene when I won ROTM last time.ROTM 2019?
