Some of my friends and I built a single triangulated 4 link rear end for a CJ7 a few years ago, and we put 3 sets of holes 1 inch apart at the upper and lower frame end mounting points. Sort of like what drag race cars use for adjustment.
With the links in the center holes, it worked pretty good. Rear squatted just a touch when you stood on the gas, drove pretty good down the road, took bumps well. Then we started moving links to see what it would do.....
Wow. You could make it completely undrivable. At one point the rear would lift about 4 inches and the tires would just spin. It was a real learning experience ( that was why we did it. It was about 10 years ago when my group started converting over to coils from leafs).
Front ends started out as radius arms, they worked ok for what we did (fast bumpy trails, no rocks), short 4 links , a little bit longer 4 links, way too long 4 links, then kinda back to about 2 ft long links. No 3 links yet, I may try that on mine next.
The point is, if there is a point, if you do not want to cut and weld, and you are around 4 inch lift on a tj, just run short arms and good shocks. Be happy.
If you are ok with cutting and welding but are not willing to experiment, buy a Savvy mid arm. Its seems to be proven to do alot of stuff well. It climbs, goes fast, handles well.
If you are willing to do the old farmer cut and try (that's what my friends and I do because we are cheap bastards), build your own. BUT.....be prepared to do it over a few times. You will learn, but it takes time to figure it out.
