NSG370 to 42RLE swap questions
ChadH
Lifetime Supporting Member
Montana
The good old discussion about trans swaps. I have been doing a lot of reading, but still have a few questions to ask, as well as some things to consider.
**Important disclaimer** I do NOT rock crawl. Rock crawling does not apply here. I never have, and now my body thanks to Uncle Sam is too broken so I never will. The TJ is my daily / grocery getter. The LJ is the weekend fun vehicle - sight seeing, camping, forest roads, river banks, etc. MOAB type stuff is not in my wheelhouse. Just to make sure my particular use case is different than the majority here. Being my DD, is not normal to most - my DD use involves going to work 2 minutes away maybe once a week, groceries also only 2 minutes away, and running to town 1-1.5 hrs one way half a dozen times a month. I do not sit in city traffic, through dozens of traffic lights every day to get to work. My town has one stop sign and is 60+ miles from the closest place for major services.
Quick background. 06 LJ already has the 42 and I intend to order a @Wranglerfix PCM possibly this week. Working on getting the right trans pan so temps can be monitored. It currently has a few symptoms, and if not warmed up or shifted slowly will bang excessively hard on the 1-2 shift so I avoid driving it until the PCM is ordered. Future plans of course include a re-gear to probably 4.88's, a setrab cooler, and gauge. Definitely appreciative of all the great knowledge and info here.
The 06 TJ is the main one in question as it currently has the NSG370. As it sits (on 33's currently, waning to return to 31's), the clutch and flywheel need replacement. The last clutch job, the dealer screwed up the flywheel and machined it far too much, so a replacement is needed. Replacement parts looks like they will be in the $1,200 range. Labor (not a job I can reasonably do) is probably somewhere around 700-1K. Pretty steep it seems but that's from a few different sources using a MOPAR flywheel and a aftermarket crown or similar OEM style replacement. Contrary to 99% of people, I actually like the 6 speed. It's fun, it has for me been reliable. However, I have had this Jeep for 10+ years and intend to keep it at least another 15. So as my joints continue to fail swapping into an auto intrigues me. But I am trying to weigh the cost/value relationship to determine when. Obviously the $2,500 or so I put into a clutch replacement could go toward the swap. But I want to make sure I fully understand what is involved before proceeding with either option. It would be lame to replace the clutch only to do a trans swap 6 months later, and equally frustrating for the clutch to fail knowing it might be another 5 years before doing a trans swap. So here are some bulletpoints as far as I understand them.
  • Currently needing clutch -$2,500
  • ATS stage 1 trans - $4,500 (minus $1,200 for core)
    • https://www.atsdiesel.com/cart
    • I know there are other options @mrblaine has mentioned but I didnt see any links. A local shop says nobody in my area will do a rebuild so if I opted for a rebuild and check on current case, it would have to be shipped out - also a problem considering the only 'shipper' is more than an hour drive away
  • Replacement harness - $1,200 minimum
    • only ones I have seen are on eBay. It would be fantastic if there was a 'new' replacement OEM option just to avoid potential internal wire problems
  • Temp gauge and Setrab cooler
  • Trans pan bung
    • I know there are options. But just for future reference what are some other options folks have had good experience with?
  • Other parts
    • shifter
    • plastic bezel on floor (tan seems a rare color these days....)
    • key interlock?
    • steering column change?
    • Replacement radiator - OEM is no longer an option apparently but I will call around. I hear 90% of the time aluminum replacements are terrible and fail. What's a guy to do for a swap, or what about 10 years from now when the OEM I do have fails.....
    • bellhousing
    • cooler lines
    • trans mount (maybe the time to do a skid plate - someone please enlighten me what the problem/issue with UFC is - I like savvy but they require a TT and I'm trying to avoid lifting the body)
    • OD switch
    • I might have just read somewhere that the crank bearings or RMS cap needs to be replaced? So you have to drop the oil pan too?
  • PCM
    • of course if I get a PCM for the TJ now being a manual, I would have to get another new one during/after the auto swap - approx $850
  • Labor
    • this is the biggest concern and potential issue. My only option for a quality shop to do this (or anything really) is J&K Customs in Missoula. They have done fantastic work for me in the past. But they seem to be going through a change in personnel and a few folks there are so new (nothing against them, it just takes time to learn) don't even know anything really about the JJ's on my current lift. So that has me concerned with 1) quality of swap, 2) how much extra cost would be added due to new employees 'learning at my expense'. Everyone has to learn, not really a big deal there. But, it still makes a guy a little nervous, I think that is a justifiable concern.
  • Rear end gearing
    • this is a biggie. I am in need of another rear rebuild, long story, and the front is probably due. I have been looking to swap in true tracks front and rear for a while for better winter traction, and change gearing. With the NGS370 and 31's, my understanding is 4.56 is a good ratio. however, with the 42RLE, it looks like 4.88's is preferred. Keeping in mind I do not plan to go the 33" route unless a 10.5" wide tire can be had, I just don't care for the extra resistance of wide tires especially since I don't rock crawl. So if I regard to 4.56 for the current 370, my understanding is that would not be deep enough for the 42RLE. But if I went to 4.88's, that might be too deep for the NSG370 at highway speeds. It's 80 here, but I rarely go above 70 in the TJ or LJ. Using grimjeeper, 4.88's in the 6spd nets a 3100rpm at 70. Which is probably ok... But if I have a tailwind it's nice to be under 3k, which is what the 4.56's offer. So ultimately before I do any gearing I really need to decide on doing, or not doing, a 43RLE swap, and when.
Does this about cover everything? Are there any other components I haven't considered? Maybe driveshafts for different lengths of the trans. Probably a flex plate as well.
Please let me know if I am missing something here. At the moment, I am feeling inclined to keep the 6speed for now simply due to cost, time needed for the swap, and winter is already on the way and I have other needed things to do that are costly - some house stuff some LJ stuff, and fixing the TJ's suspension. But I'm curios to hear what folks have to suggest.
I would not install any trans from any of the online folks and my guy is swamped. No idea what to do which is why I didn't already hop in on this one.
Yes, that would be awesome, but it is NOT an option, now what?
I have done dozens and dozens for folks, glad to do another any time.
  • Other parts
    • shifter
Shifter cable
No tan in 06. You have Khaki or almost black. Neither matters because the auto PRNDL bezel just pops into your current adapter in place of the shift boot.
    • key interlock?
Ignition interlock cable, just swap the parts onto the current column. Also need lower steering column clam shell which is different from the manual and you'll need to swap out the manual key interlock button.
No
No idea, we have not found a suitable substitute yet.
    • bellhousing
No, bellhousing does not separate from trans case.
    • cooler lines
Yes, you need cooler lines. I prefer OEM, even good used over the mess I've seen offered.
    • OD switch
And along with OD switch, you need to pull the center stack and see if the OD switch connector is there.
No, you just have to pull the pilot bearing and pilot bearing bushing and replace them with bushing for the torque converter.
  • PCM
Correct.
  • Labor
Good luck, I don't know anyone I trust.
  • Rear end gearing
05-06 flex plate only. Driveshafts are the same. The flex plate needs the stiffener and flex plate bolts.
Dipstick tube and dipstick with the hold down bolt.
All the bolts that hold the trans to the motor.
Motor plate and inspection cover with their bolts
Auto starter with bolts.
Shifter cable bracket on side of trans.
I bought all the parts someone had rounded up for the auto swap for 3500 due to just how much time that saved me hunting for them. I would do that again tomorrow instead of hunting for them.
Labor
  • My biggest issue. My only option for a quality shop to do this (or anything really) is J&K Customs in Missoula. They have done fantastic work for me in the past. But they seem to be going through a change in personnel and a few folks there are so new (nothing against them, it just takes time to learn) don't even know anything really about the JJ's on my current lift.
If you don't trust the shop then I wouldn't let them touch it.
That's a lot of really great info @mrblaine thank you for taking the time to respond! I have sourced a trans pan with the bung for the LJ but definitely would be interested in getting another one from you here maybe over winter for the future TJ swap. I agree that finding parts someone already sourced would be worth the extra cost to not have to find individual components. Is that a regular occurrence or is it just a luck of the draw and keeping an eye out on various sources for sale items? Another thought I considered is trying to pick up a donor Jeep. I've been seeing several floating around now in the 3-7K range, which might also provide other valuable parts as well. I will add a couple of these things you mentioned that I missed to the list. This is a future project I think in a couple years so I have time to collect everything necessary. I have to rebuild both axles before winter unfortunately so that's taking priority before something blows up. Maybe by then your contact for rebuilds might be available.
I know that 2 or 3 of the tech's in the shop are still there from several years ago. I trust them. There are several new folks as well though that just dont have the experience to say, use that part form manufacturer A instead of manufacturer B which is easier to access because of known problems. Thats the kinda experience that can bite someone. Unfortunately it's the best option though. Theres really not any other shops in town I know of that would even do such a job, nonetheless a quality job. Even just general services, I had issues with the dealer on warranty work for the JT. It's just how it is. Until I get a garage several years from now I have to outsource any large jobs like this, or put them on hold until I get a shop built.
I do believe I found 3 OEM radiators! Let's see if I can get them. 😬
If you can collect all the parts that will make it easy work for a tech.
If I could do it they could do it.
I found a complete engine harness for $600. My dash harness was $100 (only needed if you don't have the OD wiring behind the center section of your dash).
@Jamison C swapped one iin once and may be of help on some wiring details.
Listen to Blaine and you will be just fine.
You can call him now and see what his schedule is like. Joe at Westminster Transmission in Westminster, CA.
You can order a pallet of 25 at a time if you want to pay 620 each for them. FYI, this radiator is for a RHD. It does fit and work with a LHD if you swap the mounting flanges over off of the old one. We've done it several times.
I did not look to see if it is for an auto.
  • Love
Reactions: ChadH
I think collecting the parts will be the easy aspect. I have been seeing quite a lot of TJ's and LJ's in my area up for sale for a decent price. I have to get the axles rebuilt asap, but I think I will be looking to start picking up various 'parts jeeps'. It seems more bang for the buck that way than just trying to get new components and in many cases new components can't be had anyway. Finding someone to actually do it would be the hard part - but if you would be willing I certainly would entertain that idea.
So with a realistic swap in mind in the future, knowing I really need to get my axles built before something blows up, I was going to re-gear to 4.56 while I'm at it. That gives the option to switch back to 33's in the future, and it works for 31's for now. But, I believe the common ratio for any auto is 4.88's at a minimum correct? If that was the route to go that puts me in the 3100-3200 rpm range with the current 6spd until I have all the parts and am ready for a trans swap. Most likely the TJ will stay at 31's.
If you can find an '05-06 auto then you will have all the parts you need. However, they will have to be removed from the donor Jeep. I simply bought used parts. With parts in hand it took me 21 days to do the swap, but I wasn't working on it 9-5. I did re-loom the harness and correct some of the crappy wiring before the 21 days began. So, I'm not exactly sure how long it would take. If you have the OD switch tucked in the dash then you don't have to remove the steering wheel and dash, which saves some time. Everything has to be there as well as anything you might need like butt connectors, tools, et. al., so you don't run into needing something that takes 2-5 days to ship. You aim for something like 3 days. The only time possible for me would be during Summer's, but I would have to take off work.
Reactions: ChadH
That's helpful info thank you. It sounds like I have some work to do and planning ahead of time. I also dont want you to have to take off work maybe we can chat about that later. I'll probably start sorting things out this winter and look to pick up a donor Jeep, send the trans off for a rebuild - that seems to be the easiest way to go and a bonus of having a whole lot of OEM replacement parts. I think this will be a longer term project maybe a year or two down the road.
@mrblaine Just had a real nice chat with Joe. Thank you for the reference. 🍻 After chatting with him I wouldn't even consider having anyone else build a transmission unless he closes shop some day. Funny thing he was just in my area earlier this month visiting family. What a small world. I will probably schedule time for him to rebuild the LJ trans, not that it's bad but just to avoid future issues.
Reactions: JMT
One of the best calls you have made and you won't go wrong with Joe @WM.
