New TJ owner in the last few weeks, 05 with manual 6 speed and had a question on the nsg370. I’m having the grinding into reverse issue. I’ve taken all the advice and can avoid it using various techniques.
However I am a bit confused with all the reading I’ve done here and online, reading thru the nsg manual, etc.
The clarification I’m looking for is this: the manual clearly indicates there is a reverse sync ring but the advice that “works” is based on techniques as if there were no synchro on reverse. Is it just simply that even though the trans has a sync ring it still needs to be treated like it doesn’t?
thanks in advance!
thanks in advance!
