1. Want to have your TJ featured as the March 2018 "Ride of the Month"? Click here to submit a photo of your TJ. Submissions are accepted until February 20th!
    Dismiss Notice
Nth degree skid system
Discussion in 'Parts for Sale' started by burghermike, Jan 23, 2018.
  1. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    For sale an Nth auto skid system for tj/LJ 04-06 complete. Selling only because I have a Manual tranny. I am asking $350 buyer pays shipping. I m located in Western Pa
    8598c94b5083e47d034a59dfc9281c1e.jpg 5624f733b5acc032aab6177501aa248e.jpg 0e0ae5b255e05fac872b768aa3126146.jpg d8423346aba6b13d09e8ebd70202ab8c.jpg
  2. KMG
    KMG Member
    Dec 27, 2017
    70
    87
    Midwest
    Does using this skid on a stock 04 rubicon require a MML or body lift? Does it fit with an automatic?
    Thanks, Kevin
  3. KMG
    KMG Member
    Dec 27, 2017
    70
    87
    Midwest
    Is your skid plate still for sale?
  4. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    20,822
    11,241
    Salem, Oregon
    It fits with an automatic, but it does require a 1” body lift.
    KMG likes this.
  5. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    Sorry for the delay. Duty called and I responded. Answers. KMG, yes on the rubi requires an automatic tranny, it’s still for sale. It does not require a a BL, it will fit years ‘04-‘06 Tj , automatic and May require a different hanger bracket for CC hanger which is with the parts. All parts are with it. Another thought, Rubicon model has a pump in the rear and the plate accommodates this with a section that has a well built into it. The other difference is the gusseting on the plate and their location. Once this is sold I will go this route with the replacement for the manual tranny.
    Sent from my iPad using Tapatalk
    JMT likes this.
  6. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    In addition. Thanks for your patience
  7. T Crawford
    T Crawford Member
    Feb 4, 2017
    27
    12
    PNW
    I have this stuff on an 06 lj. No body lift had to dimple the transmission tunnel in one spot it came with a “tool” that was I think 1.5”OD 2” pipe cut in half to make the dimple to clear top bolt of transmission inthink
  8. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    Can you clarify this explanation. When I installed this it seem to push things up and out of sorts. I was concerned about vibes and mis alignments
  9. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    I am currently looking at ucf’s skid plate. No BL required. I’m trying to avoid the BL & MML due to the increase in height with the Currie 4” suspension lift. A higher COG changes things. I would like to remain as is.
  10. JMT
    JMT TJ Expert
    Feb 27, 2017
    3,018
    2,684
    Texas Hill Country, United States
    If you use UCFs low-pro mount to get a higher clearance skid, beware of the vibes transferred to body at 500-900 rpm’s. UCF, good stuff and I’ll go that way when I’m ready to get rid of my fat tummy
  11. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    Lol. Got it. lol pro is part of pkg. will vibes be remedied with pinion adj? It has a SYE
  12. T Crawford
    T Crawford Member
    Feb 4, 2017
    27
    12
    PNW
    On my 04 rubicon lj auto I ran this with an ome lift for several years with stock control arms and only really Monroe vibrations. Later I put Jks front and rear adjustable arms all the way around and that made it a little better
  13. JMT
    JMT TJ Expert
    Feb 27, 2017
    3,018
    2,684
    Unfortunately, no, there is something about the transmission mounts bushings that don’t sufficiently stamp out the vibes. The harmonic range our TJ tubs transmit are produced in the 500-900rpm range, which is idle. Once you hit the gas they’ll go away. If you can live with it, so be it. If not, you might rethink MML and BL.
  14. burghermike
    burghermike Member
    Thread Starter
    Nov 17, 2017
    30
    11
    Beaver Falla Pa
    Thanks. Got it! How bad are the vibes at idle. Enough o annoy or give a genuine concern about collateral damage or more maintenance?
  15. T Crawford
    T Crawford Member
    Feb 4, 2017
    27
    12
    PNW
    Not bad at all little rumble in the seat of your pants you get used too rof4x4 had a thread where you could get softer mounts from McMaster car but I never followed through
  16. Ron505
    Ron505 TJ Enthusiast
    Dec 11, 2015
    455
    293
    Southeastern Ohio
    This kit should work on an '03 as well, no? Does this offer any tuck at all? Can you list the part numbers by chance? I'll be in Pitt in a few weeks.
  17. RangerRick
    RangerRick TJ Enthusiast
    Aug 12, 2016
    125
    121
    West Coast
    I used to be an Nth dealer for several years. Yes this tummy tucker will work with 2003-2006 frames. You can contact the new Nth Degree and get a mount for a manual transmission so that shouldn't be a hangup there. The break is 2003 & up, 2002 and down won't fit due to the hole alignment for the frame mounting points.
    RR
Share This Page
