I have a 2001 TJ 4.0 with an NV3550. I had some normal nv grinding from 1-2 and then got worse on downshifting. Just recently it started to come out of third when decelerating so I took it to a shop and long story short I need a transmission and a clutch no surprise which they quoted me 4900.
They are looking at putting a Rockland Terminator in it any advise on that? I have looked it to it and I can probably do the swap on it my shelf for almost half the cost so I am leaning that way as I have a shop for the winter. Is it an easy swap or any common problems with doing it? And also while I’m doing the clutch and tans is it worth doing the rear main seal if it is leaking a little or worth replacing anything else? Appreciate any tips.
Mostly a weekend cruiser now with off-road trails a couple times a year. Looking to build into a drivable trail rig one day.
