Hi all,
Well it looks like the 4.6 with its 400 n/m has had it's way with my much loved NV3550. It's making a grinding noise if you load it up under 1,500 RPM in second and third gear, and leaking a small amount of oil from the bellhousing making the clutch shudder a little at very low revs. Strange thing, it if I drive it like I stole it the box sounds good.
I would like to rebuild it and not sure what kit or parts to buy from rockauto. How do I work out which one of these kits suites my countershaft bearings 1.30 or 1.18?
Trans. code NV3550; 0.9 inch wide input/output bearings, 1.30 inch I.D. counter shaft bearings, multi-piece 1st-2nd gear synchro rings, w/reverse synchro ring
Trans. code NV3550; 0.9 inch wide input/output bearings, 1.18 inch I.D. counter shaft bearings, multi-piece 1st-2nd gear synchro rings, w/reverse synchro ring
https://www.rockauto.com/en/catalog/jeep,2001,wrangler,4.0l+l6,1373723,transmission-manual
I would appreciate any advice as to what else might be worth replacing after 120,000+ miles of service? Keep in mind apart from the two issues mentioned above (grinding noise if you load it up under 1,500 RPM in third gear and leaking a small amount of oil from the bell housing) it is shifting just like it did when it was new.
Also, I have a near free shipping option from CA to AU so a full replacement/recondition box is also an option.
