NV3550 transmission reverse light wiring
Rebuild
Lifetime Supporting Member
British Columbia Canada
1998 TJ, I replace my AX5 with an NV3550. Long story short I removed the 4cyl and dropped in an Ls. Everything is spot on except the reverse lights. I have the female coming out of the Nv 3550 transmission, any idea how to tie in the wiring in to the Jeep?
Reactions: wes11b10
It should be a 2 pin weatherpack connector which are commonly available.
Thank you, I have that, I am looking at how to connect the 2 pin to the Jeep. There is a harness on the drivers side frame, but no wires that resemble the back up light wire ( purple )
