2005 Wrangler TJ Rubi
I am getting the error code P0058 "Heater Control Circuit bank 2 sensor 2"
What I have done so far...
I replaced all four 02 sensors with NTK
I replaced the catalytic converter.
It worked well for about a week (2 maybe 3 small drives) then the CEL returned and its P0058 again.
I returned and replaced the bank 2 sensor 2 again.. still have the code after trying to clear it
I started pulling the wiring harness yesterday and didn't see any noticeable damage anywhere. My harness loom is shot and crumbling btw.
On a scan tool I can see its getting power with key on (1.27 for all o2 sensors) and while running a can see the graph change value for all except B2S2
Can I run my own harness to the o2 sensor from the PCM? The FSM says...
pin 33 on Black terminal is the signal
pin 10 on Neutral terminal is the Heater Control
The other two wires on the sensor should be grounds and I can ground to the frame, Correct?
What is the Pin 32 on Orange "O2 return, Downstream"
I also noticed I already have a remanufactured PCM. Came that way.
Did I miss something? Is there something else I need to be looking at?
Thank you in advance
