WTB: OEM black torx screws for headlights not the outer trim ring, the inner headlight retainer ring screws
DeadStang
Albany, Oregon
I need several (as many as I can get — I have 4 LJs) of the little torx #6 x 1/2" or 5/8" (I am not sure how long they are but they are no longer then 5/8") black screws that hold the headlight inner retainer rings in place. I am upgrading headlights and am finding that I am missing screws from each headlight as I work on them. I like to keep things stock and don't want to have to switch to standard Phillips screws as I do this little project. IM me with what you have. Thanks.
I understand not wanting them mixed.
Maybe replace one Jeep with all phillips head and then you'll have some extra torxs for the other Jeeps. ;)
Did you look inside the grille?
That's where all of mine always fall.
Not black but jeephardware.com haa these.
24 ea Jeep Wrangler Headlight, Tail Light, Turn Signal & Park Light Torx Screw​
https://jeephardware.com/product/24...ht-turn-signal-park-light-torx-screw/#reviews
$16.99
24 ea Jeep Wrangler Headlight, Tail Light, Turn Signal & Park Light Torx Screw quantity
ADD TO CART
Complete 24 piece Stainless Steel Torx Screw Headlight, Turn Signal, Running Light and Tail Light Kit.
(you get 24 each stainless steel torx screw kit for one jeep wrangler) Part Numbers 06035977AA and 06035781
24 each Brand New 1987 to 2006 Jeep Wrangler Lighting System Torx Screws.
These torx screws will fit any jeep wrangler YJ or TJ Lighting System.
May fit many other years.
OEM Grade Five Automotive stainless Steel.
Fits All YJ Wranglers
1987,1988,1989,1990,1991,1992,1993,1994 and 1995
1987 to 1995 YJ model original screws were Phillips head style, This is a conversion to torx screws. They are a perfect thread, diameter and length. (see pictures)
Fits All TJ Wranglers (OEM Style)
1997,1998,1999,2000,2001,2002,2003,2004,2005 and 2006 .
You Get 24 Each Brand New (OEM Grade 5) Stainless Steel jeep wrangler torx screws!!
These?
Reactions: DeadStang
$16.99
ADD TO CART
I saw that but wasn't sure if they were going to be correct because they are all stainless — maybe (obviously?) that's irrelevant.
This is one of mine. The inner are black and the outer that hold the trim ring are stainless/chrome in appearance.
I bought from him before. This is his side hustle. I gave him a call with a question and he answered while he was out hunting. I’d give him a call and ask.
