I’ve discovered an issue with my new to me 2006 TJ with the in-dash CD/Radio. The radio is listed as the sales code RBK - AM/ FM STEREO RADIO WITH CD PLAYER AND CD CHANGER CONTROLS. First off when I put in a CD, it seems to recognize the disc because the display gives ERR, then quickly returns to the FM station that I was listening too. If I press the mode button, nothing happens. The unit doesn’t seem to want to play the CD. Also, the unit is supposed to have Sirius/XM capability according to the owner’s manual. In fact there is a Sirius/XM antenna on the window frame. But again, the manual says to press Mode to switch between Satellite radio and the CD player and the mode button doesn’t do a thing.
The previous owner mentioned that he had to replace the PCM to fix a heater (or defroster?) issue. Could the replacement PCM be causing the problem with the radio? Or is it just a faulty radio?
