Okay so to start from the beginning I bought a 2001 jeep Tj and it always had oiling issues but one day the gauge dropped to 0 and never went back up so I rebuilt the motor in hopes to fix it and the gauge still reads 0. I have replaced the sending unit and still nothing, I use a manual gauge and oil pressure is fine but the dash still sits at 0. checked for voltage on the pins at the pig tail connector and pin one which is power is at .10 volts believe it is supposed to be 5v and pin 2 which the pressure sensor signal is also reading .10v I tried grounding the pins and the only one that moved the gauge was on pin one which is power and all the gauges dropped to 0 and didn’t read key in the ignition also PIN number one also looks bent maybe that’s the answer??? am almost ready to get her back on the dirt but can’t figure this out for the life of me any ideas???
