Have problem sometimes with my 2001 4.0. Sometimes when I crank it up the oil pressure doesn’t come up right away. It comes up real slow. It comes up so slow when it does this the check gauges light comes on for like 2 seconds then it’s up to normal pressure. When it does this it throws an oil pressure code and the check engine light comes back on. When I run it I never have low or high pressure problems. Already changed the oil sending unit and it didn’t help. Doesn’t do this all the time and I’ve noticed it mostly does it if it’s been sitting for a couple days or is really cold. If you guys think it could be something serious let me know. Otherwise I’ll just live with it. This TJ is maintained like clock work with oil the manufacture calls for. Oil isn’t low, doesn’t fluctuate much when driving, and doesn’t smoke at all. Only doesn’t maybe every 3 to 4 startups. Thank you for your advice guys. Just need to know if it’s something I need to address if it can cause me problems down the road. Still feels like it can pull a house down in 1st and 2nd gear lol. No performance loss.
