Screws directly to the block horizontally, I couldn't get a new filter today so I will swap it during the week.Off the top of my head Wix 51515 is I believe a Ford filter that is considerably larger that fits. I ran then for a long time on my Golen stroker which had the 90 degree filter adapter mount thingy. Just eyeballing it I don't think it'll fit on my current (stock for a '98 block) setup and I just run whatever stock is. Do you have that mount adapter thing or does it just screw directly to the block?
Video of the noise would help, but I understand the challenge of catching it.
So what then the lifters are leaking down?I don't think it has anything to do with the filter.
No additive and it was the same with the 10w-30, the 10w-40 Magnatec semi I am running is a recommended replacement for 10w-30 conventionalI think so, yeah. I just changed my oil the other day. Completely dry filter and no clackity clack. Didn't you say you were running thicker oil or some kind of additive or something? Did this noise happen before that?
Let me know if your filter has any or much oil, its supposed to have a fair bit, My filter is usually quite full but I warm the engine before a change then let it cool a bit, this time I just changed the filter and didnt start it up and it was empty so the anti drain back cant be working?, I read everything I could find about this even really old jeep forum threads and it seems some of the cold start rattles were cured by using 5w-30 so the full synth may work for you but most couldn't find a cure and just lived with it, most used suggestion was leave your radio volume up when you start up and forget about it lolFishtaco it's time for me to change my oil this week and I'm going to use Valvoline Full Synthetic Advanced 10W-30 instead of my usual Valvoline or Castrol High Mileage blend. I do believe from your explanation I have the same 2 second startup rattle you have only difference being mine happens during cooler weather NEVER during the summer. I've read where using a heavier weight motor oil will not help loud lifters and a full synthetic oil may stop startup lifter clatter experienced only during cold temps. I don't consider temps in the 50's all that cold but my Jeep does?!
