Seems like the 4.0l . . . will take any 10w30.. but from what others have said.. stick to conventional, synthetic can cause the rear main seal to leak.. I personally like valvoline.. but any sae verified oil should work great....
Any motor oil that meets the manufacturer's specifications is acceptable.
The 2006 Factory Service Manual, in the Lubrication & Maintenance section at page 2, specifies motor oil certified by the American Petroleum Institute for gasoline engines with an SAE viscosity rating of 10w30 for ambient temperatures ranging from 0*F to 100*F and above and 5w30 for ambient temperatures from -20*F up to 100*F. There is no recommendation as to conventional, synthetic blend, or full synthetic motor oil.
I don't think there is any objective evidence that synthetic motor oil can cause the rear main seal in the 4.0 engine to leak. There is some support for the belief that full synthetic motor oil can dissolve deposits masking evidence of existing leaks, but the theory that synthetic motor oil causes leaks was debunked decades ago. In any event, the anecdotal evidence on the issue is inconsistent and can be used to support or refute whatever one's personal belief happens to be.
My anecdotal evidence is this: The previous owner of my LJ was using Mobil 1 10w30 full synthetic. There was a minor main seal drip. I switched to Valvoline Maxlife synthetic blend 10w30. The drip stopped. Will the drip stay stopped? No one knows and time will tell. Can I draw any valid conclusions from my observations? No, not really.
Ok so I just picked up some Mobile 1 synthetic high mileage 10w30 oil.
This will be my second oil change since I bought my Jeep and unfortunately I can’t remember what I used the first time. I did however use the mopar oil filter last time and I will again this time.
It maybe a little complicated to explain about the particle compositions.
Analogy: Let's say gravel and sand. Gravel is the dino oil and sand is the synthetic oil.
Gravel will not pass through as easy as the sand will do through the tiny cracks
The leak is stopped by the dino blend particles.
In full synthetic high mileage oils they have conditioners that plug those "tiny holes". . . . . Valvoline Maxlife, like Mr. Bills referenced works for him and although it is to small of a sample size to tell, but he had a small leak stop after switching.
That's exactly what I run too. I'd only switch to a synthetic engine oil if I lived where the temps get below zero where synthetic does have a legitimate advantage over conventional. I do run synthetics elsewhere like in the transmission & power steering (ATF+4) but I would not in the engine where I live.A month ago I changed to Valvoline regular 10w30 and not a drop since. FWIW.
I just purchased 10w30 Rotella T-4 oil and a Wix 51515 oil filter for my next oil change this weekend.
