They don't change steady state, in other words once you are a second or two into the turn the shocks don't change the total roll at all really.Shocks can have a significant affect on body roll.
Okay, you're set on this, I get it.Not true.
Ok…as said not sure…shock absorbers resistance is governed by the velocity of displacement primarily vs springs being based on total displacement (correct?)…so slower movements should see less resistance from shocks. With that said, I don’t know what they are really tuned for and where the damping becomes significant.Not true.
So, I don’t know about all the new shock technology, but basic shocks have dampening proportional to the rate of displacement of the shocks…whereas springs provide resistance proportional to displacement. So multiple factors come into play…initially the shock might provide the most resistance, and the faster you shift the body weight (take the turn) the more resistance the shock is going to give. As you go around the curve and start to roll more, the resistance from the spring becomes greater. Without knowing the tune for each system (and every system is going to be different), I can’t really say where and to what proportion each component plays.They don't change steady state, in other words once you are a second or two into the turn the shocks don't change the total roll at all really.
Good to know and gets back to the question I was asking originally, should I get adjustable shocks…is there enough difference to make them worth setting one way for off-road and another for on road? I tend to do several hundred mile trips in my TJ and then off-road with it…so, what’s the best set up, a single setting shock, or multiple setting shock…and then do I set for soft or stiff for best on/off road performance? I apologize if this has been answered in previous thread.Yeah. I'm set on this because I can demonstrate it by adjusting my shock settings.
Maybe in a vacuum, but in the real world they are active throughout. The front and rear wheels don't travel the same arch, steering may shift, road texture, acceleration, pitch, ...They don't change steady state, in other words once you are a second or two into the turn the shocks don't change the total roll at all really.
Ignore what you think the springs are doing, because they aren't doing that.Ok…as said not sure…shock absorbers resistance is governed by the velocity of displacement primarily vs springs being based on total displacement (correct?)…so slower movements should see less resistance from shocks. With that said, I don’t know what they are really tuned for and where the damping becomes significant.
I know nothing about how off the shelf adjustables perform. All I am going to tell you is that shocks matter and they matter a lot. And anyone who says otherwise has never had the experience of a shock transforming the very character of a vehicle to where they become a significant portion of what the suspension is built around.Good to know and gets back to the question I was asking originally, should I get adjustable shocks…is there enough difference to make them worth setting one way for off-road and another for on road? I tend to do several hundred mile trips in my TJ and then off-road with it…so, what’s the best set up, a single setting shock, or multiple setting shock…and then do I set for soft or stiff for best on/off road performance? I apologize if this has been answered in previous thread.
Not sure what you mean by first statement, but in the case of body roll, we can imagine two scenarios, a solid bar for springs (k = infinity) and virtually no spring (k = 0). In the first case, there would be no body roll at all, and the shock would be irrelevant. In the second case, the harder you take the corner you have competition between the force of the body on the shock and the amount of dampening from the shock.Ignore what you think the springs are doing, because they aren't doing that.
The shock valving controls how the shock piston moves through the oil in the shock body. Different kinds of valving can have very dramatic effects on small and large events, fast and slow events.
I can change my rears right now to be fairly soft and cushy, noticable roll around corners, and lots of movement on uneven surfaces; all the way to feeling almost every crack in the road, and staying nearly flat in the corners.
Mine also have a small flutter stack to help soak up the small event stuff without creating too much roll. I am aware of others with too wide of a flutter that allows for too much movement.
I'm not doing the spring thing again. They aren't contributing to more or less body roll beyond what they do to create the ride height. Do yourself a favor and remove the shocks and go for a drive to see what the springs really to do control any movement.Not sure what you mean by first statement, but in the case of body roll, we can imagine two scenarios, a solid bar for springs (k = infinity) and virtually no spring (k = 0). In the first case, there would be no body roll at all, and the shock would be irrelevant. In the second case, the harder you take the corner you have competition between the force of the body on the shock and the amount of dampening from the shock.
The rest of what you said I totally agree with, and this is a complex system where both components play, and the weight of each is dependent on their parameters.
... and I have seen Fox 2.0 RR with DSC called best. Sadly it is not cheep to experiment.
It's ok. You don't know what you don't know.When talking about roll the shocks don't limit the roll after about a second. You can flap your jaw until you are blue in the face but the fact is that is as certain as springs setting the ride height. Once the turn is set roll is determined by the sway bars and the springs just like the Jeep is sitting on flat ground and has nothing to do with the shocks. I said clearly that quick actions are controlled by the shocks, slow set turns are not.
Ya, the shocks hold the Jeep in a turn. Makes sense to me considering they are fluid dampers. You haven't thought it out or just don't understand.It's ok. You don't know what you don't know.
Why did you ignore all the dynamic forces I cite?You haven't thought it out or just don't understand.
What are you even talking about, shocks don't change how much your Jeep leans getting on the freeway. Give this stupid shit up.Why did you ignore all the dynamic forces I cite?
That doesn't answer my question and in fact you're now trying to change it entirely. Most of us know which one of us is being stupid, but at least you finally learned to quote.What are you even talking about, shocks don't change how much your Jeep leans getting on the freeway. Give this stupid shit up.
All you are doing is showing us what you don't know. Stop it.What are you even talking about, shocks don't change how much your Jeep leans getting on the freeway. Give this stupid shit up.
