Original Safari Top
Chief Brohician
'98 TJ Sport '11 Extreme Camper '18 JLU Sahara
Lifetime Supporting Member
Guntersville, AL
The wife bought her 1998 TJ Sport Hardtop Memorial Day Weekend 1998. It came with a Safari Top that extends to the top middle row bar. How do I install this top? Do I need some kind of header bar for it to attach the windshield and the Safari top together??
I looked at the information. I pulled out the Safari top / bikini top and I do not have that channel in the windshield. There is a gasket but it is not grooved like the instructions show.
Most likely you have a bikini top that installs via a "drill" in style header. The header stays mounted when the soft top is up. I am also guessing your bikini top has one edge that is thicker using a rope that is inserted into the header channel. If this is what you have, you would need to have that specific header to use that top and I can tell that Bestop (the original manufacturer) no longer makes this style of drill in header. The bikini tops they offer now use a thinner plastic piece in the bikini and the corresponding header channel will be too thin for the older rope style to work.
  • Dislike
Reactions: Chief Brohician
Ok, I have the original hard top, no soft top. Unsure why they wouldn't include the Safari top without the header bar installed. Trying to keep mah bald head from the sun.
