Other than factory zerks, where else to grease suspension?
SSTJ
Inexperienced Overthinker
Lifetime Supporting Member
South Carolina
On a stock TJ, other than the seven zerk fittings, is there any part of the suspension that should be greased periodically?
97' 4 Popper
"The Bucket and the Beast"
CNY
The driveshafts is one area people forget, early models had greaseable u joints and depending on what replacement you use you could have those on a later model as well.
SSTJ
SSTJ
South Carolina
Thanks. So no other parts of the suspension though?
As for the driveshaft, thanks. I have an early model, so I'm interested. What makes a u-joint greaseable vs not? Or what exactly was different about our early model ones? Thanks.
Reactions: 97' 4 Popper
JMT
Saxum Erepo 🪨
If the ujoint has a zerk it’s greaseable.
Reactions: SSTJ
SSTJ
SSTJ
South Carolina
Thanks for this. My 97 doesn't have zerks on the driveshaft u-joints. It's an SE, so maybe this was only on early model Sports and Saharas?
SSTJ
SSTJ
South Carolina
So there's no need to grease the control arms joints?
97' 4 Popper
CNY
My 97 4 popper had them but I guess it could just be from replacement u joints. I havent seen that style on my 2006, 2005, or the 06 I had before.
Reactions: SSTJ
