Overland LJR built to Explore and Expedition
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
San Francisco, CA, USA
Those freshly coated Savvy control arms are already filthy? Haha!
Antiseize. You mentioned you had a hard time taking some apart, were a few of them hard to really tighten down?
What CA’s did you take off your rig?
Stock uppers
Fixed length skyjacker lowers
I plan in dialing them in but didn’t have time.
Likes: JMT
Chris
Administrator
Staff Member
Sep 28, 2015
33,268
20,450
Salem, Oregon
No, but this could be due to the powder coating. It's possible that trace amounts got in the threaded area, which can of course make it harder to tighten them down the first few times. Happened to me before on a number of other things.
Alex01
Enthusiast
1,277
1,309
Martinez, CA, USA
Too bad they didn't think to throw a cotton ball or something in the hole to block the threads from being sprayed.
Nice seat covers by the way Chris.
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
My Savvy transmission and belly up skid are finally shipping which is very exciting :). Next week I'll probably order the rockers too which they have 3 in stock (I moved this forward to make sure I get it in time)! That'll keep me busy for a bit..
After all that, it would really just be brakes, 35s , a rear bumper, and some sound proofing and my plan will be complete for Moab.
Definitely a lot of wrenching to do in the short term but at least the two months leading to Moab (changing tires, soundproofing) should be easier.
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
Figure out the timeline on getting your parts powder coated so we can put Hollister on the calendar. :p
Its hard to think that the rear track bar will finally be unboxed and installed this weekend after all this time lol.
I don’t see the powder coating taking more than a week, this isn’t Oregon!
I’m thinking like second weekend of March weather depending (and if there’s no big event at hollister)
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
My old coax had a bit too much slack in it and as a result was hitting something on the engine ( I route mine under the Jeep) and had melted, swapped that out and I have a working CB again.
Replaced my front trackbar with a Currie I bought from @toximus and put on a new Monroe steering stabilizer (not sure what was on there before and I figured for $25 have something I know on there, trying to diagnose my slight pull to the left before Moab)
I think the pull is slightly better, didn’t get a chance to put on my poor rear trackbar which has been sitting around for a year. Next time!
Mar 29, 2018
1,051
756
Northern WI
If I included the steering stabilizer with the linkage, it was only a few months old and Monroe. I would do all debugging without the steering stabilizer. Add it in only once you have everything figured out. The purpose of the stabilizer is to reduce wear on the steering gear.
Likes: tomtaylz
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
I just bought a new Monroe one I was talking about whatever was on from the PO, yeah I think I’ll start more aggressively debugging soon, I need to get the rear trackbar I have on too and make sure everything is centered and angles are correct also. At this point it is pretty slight, if you let go of the steering it more wanders to the left vs a more aggressive jerk.
tomtaylz
tomtaylz
LJR Addict
1,595
1,594
So gathering my thoughts:
Tomorrow I'm going to order the Savvy LJ Rockers as they are in stock! I am going to order a Tom Woods rear drive shaft too in the new future as I don't see doing the tummy tuck without one hah.
Once I have the rockers, the belly up, engine skid and "step" is going to get powder coated black. I'm going to rattle can the aluminum backers with some mopar paint and clear coat - hoping that it will look decent enough but I don't want to spend a lot of money due to the possible future repaint (not this year)
Next chunks of work
Savvy Shifter Cable
Locker Pump relocation
Rear track bar
Belly Up - if some exhaust work needs to be done, I need to figure out a decent way of doing that. Limp mode to an exhaust shop?
Engine/Transmission Skid
On the horizon:
Feb - Brakes and Regearing
March - Tires
