Looks good! Ditch the shock boots brah.
Is there any negative side effects to that? Didn’t know if it was something where if sand got in there it would cause friction or wearing
The boots are actually detrimental. They will collect debris, eventually tear, and promote rust of the shock. The shock piston is self cleaning.
So I had tried to adjust the parking brake to no luck. It was annoying as I live on a hill and was parking on the flat part at the top of the hill.
I took it to my mechanic as I’ll be traveling a lot and would prefer my new being closer to home so my friend can keep an eye on it. Well I found out why my adjusting wasn’t working. Turns out at some point someone removed the parking brake components. I’m having them just put on an after market kit, he was saying the dealer sells springs and things individually and would cost a lot to buy the parts new.
WTF? Why would someone remove your park brake components? Does your jeep have rear disc brakes?
Were the park brake cables missing too?
So bizarre! I just adjusted my park brakes over the weekend by adjusting the star adjusters. I wouldn't know what to think if I went to adjust them and all the hardware was missing. That just floors me! I'm guessing that you must have noticed something wasn't right when pulling park brake handle and having no resistance?
What kit did you order? there isn't much to the park brake system. 2 springs, some retainer clips, adjuster, and, of course, park brake shoes.
Well not having the pads really explains why adjusting the brake made no difference. Everything else looked to be in place I didn't even think to look for pads. lolYeah exactly, I didn’t think the parts weren’t there though, we cranked down the adjuster under the tub quite a bit and confused why nothing was happening hah
Did you guys pull the rotor hat off to discover everything was missing?
