Just from the prospective of sitting in the seat while idling it seems a lot more refined. Before at idle the seat would shake to the point of annoyance. (probably due to the transfer case being so close to the tub after the TT) Since the seat is now mounted on top of a layer of rubber and foam, therefore isolating it from the bare tub, it has severely reduced the shake.Turned out nice and clean. Hope it quiets up those pesky vibes.
Before adding the dynamat I played with the pinion angles a bit to where at 75mph the vib felt consistent with the idle shake, so with any luck it will ride much better. But, this is Tom's weight sensitive LJ and we just added around 60-80 lbs so WHO KNOWS.....
