I hope they make noise.
Have I not told you all about my side gig? The Jeep is now a perfect compliment...
I thought I squashed this... after parking outside in the cold over night I got the CPS pending CEL and limp mode. As usual, once the engine gets to temp and I stop/start it runs fine. It even was happy all the way home from the springs (~60mi).
It’s probably time to find originals now, not the garbage OEM replacements or whatever is in mine. Or maybe I just accept this minor irritation and have another car for these weekend needs...
The CEL is still there, but I want to see if it will clear itself.
Edit: the code was gone after running out to pull into the garage for the night
Interesting. I know on the earlier models the CPS code is the same numerical code for the CAM sensor. Do you know if it is that way on the older models? Or have you looked at the CAM sensor?
Now that you are an expert do you want to do mine? The wind caught the screen door and ripped it out of the frame. Its been on my to-do list for quite a while now.
Good catch! How many miles since the spacer install? Could just be a one time thing and you caught it just in time.
Those are the rear springs I am running. I dont think you will run into many issues. Just make sure your shocks will work with the new 4" liftI’m about to order some 4” springs (Currie/Rockjock) and their bump stops for the lower perches. I was curious, however, of the LJ springs for the rear (CE-9131RH3P). I think @strumble8 and @toximus may have some experience with these. Are they the right ones to get?
Any gotchas I should be aware of going from 2” to 4”? I have the angled bracket (JKS), adjustable TBs and shock relocators (that I indend to be somewhat temporary).
