Was having acceleration bucking intermittent every few weeks and indicator light finally came on for me to get codes checked at auto store and 0016 and 0344both came up.
I changed the OPDA (2 years ago) due to a little noise in OPDA, gear wasn't bad at all, did not put original OEM pigtail back on, used new one. I have read now this can cause issues.
Not sure where to start. Shall I switch the pigtail only or do you think I should take OPDA off and look inside? Not having any noise now. Anything else I should do or look into? I looked at all of the wires for the crankshaft sensor and camshaft sensor and none are frayed, all look great. Will spray with some contact cleaner. When I do that, do I take apart the plastic harness connections? Sometimes they can be a pain to unhook.
Also, just to be sure I was looking at right sensor, where is the crankshaft position sensor?
And the pigtail on the OPDA, that's the camshaft position sensor?
Thank you for any ideas
