Just did a search, nothing popped up. I have a 2005 TJ X 4.0 6sp. Last night I drive the Jeep, and all was fine. Wife wanted my truck today, so I drove the TJ to work this morning, and the CEL lit halfway down the block. It still is running as usual, with no symptoms, just the CEL. When I got to work, I cycled the key 3 times, and it read P0068. I'll check for vacuum leaks when home.
History, about 2 months ago, I had P0022 (IIRC) for the TPS. I put in a crown TPS, cleared the code, and it has never returned. A few years ago, I replaced the master cylinder and booster, as the master was leaking into the booster. (slowly lost brake pressure after the Jeep fully warmed up. Had good pressure initially when stopping, but the pedal would slowly go to floor at a stop light). Back in 2011 it would randomly throw a CEL for Bank2 O2, but was random, and has not occured in the past 5+ years.
Any other things simple to check?
