Hello, the last few months I have occasionally been getting a P0174 code, stating bank 2 is running too lean. I replaced all 4 O2 sensors but it did not help.
Thanks to @AndyG i learned a bit about fuel trim from this site and tested it with my code reader. At idle, the short term trims hover around 12%. When I go up to 3k rpm they’ll settle around 30%. Based on that link its not a vacuum leak, and could be the MAF, fuel pressure, or injectors.
Anyone have any experience with this, or know any other relatively easy tests I could perform at home? I did clean our my throttle body well last year which I saw mentioned on another post, maybe I could try that again more thoroughly. Preferably would like to do this myself instead of a shop, but some of the tests I saw look like they’d be more suited for a shop to do
