Have an 05 TJ 4L I6. Had a misfire issue when I bought in 2020, let it run until it started having major problems with the following: acceleration on the highway, idling rough, multiple turns of the key to start. When I first got it, replaced the starter and spark plugs (used autolite plugs like an idiot).
Recently with the issues worsening, I have replaced the following with the recommended part replacement:
-IAC valve/sensor
-MAP sensor
-TPS (back of throttle body)
-the little sensor connected to the intake
-all spark plugs
-spark plug coil rail
-fuel injectors
-O2 sensors
The most recent repair being tonight (the Throttle Position Sensor).
Haven’t read the fuel trims after replacing because my buddy who had the scanner moved, but before they were high, like -32% high. Plus it has constantly thrown the code P0175 (among other codes), so naturally I assumed it’s running rich which makes sense. All spark plugs are gapped properly and did extensive research to ensure I got the best ones that the Jeep wouldn’t have issues with.
Brings me to this post, I’m at my wits end with this hunk of metal, just want it to run until I move back to the mainland. It’s still throwing the P0175 code and isn’t running like it should, haven’t Road tested yet, it’s my wife’s vehicle so she’ll let me know tomorrow if the issues persist (probably with considering the code).
Any advice or parts you recommend I check are appreciated. Love all the TJ owners out there, but damn I’m never buying a TJ again lol.
-IAC valve/sensor
-MAP sensor
-all spark plugs
-fuel injectors
-O2 sensors
