P0301 not fixed after 1 month at dealership
2002TJ
maryland
I have a 2002 TJ with 153,000 miles on it.
Full tune up in winter 2017.
One month ago the jeep was running so rough and multiple codes came up: P0320, P0300, P0301, P0306.
I took the jeep to a local mechanic - he was unable to diagnose and suggested the jeep dealer. The jeep was at the dealer for 1 month.
Fixes included ignition coil, crank sensor, all of the plugs replaced, injectors switched around and cleaned, replaced the injector O rings, checked gas tank and fuel pump and filter. Ran the jeep for long drives and the P0301 misfire code continues to come on -missing slightly they say. They have had 5 techs and a foreman review it and are stumped. They said that everything checks out fine and perhaps its an engine internal error. I have it home now and the light just came back on.
What else can I check that the certified mechanics could miss? Bad, loose, cracked fuel cap? Bad battery? Suggestions please! I have spent hours and hours trying to figure this out.
Thank you!
twistedlv
Las Vegas
Thank you!
Anything that affects crankshaft speed can cause a misfire dtc. Could be something as simple as a vacuum leak. Is the P0301 the only code you still get, and the others are cleared up?
Download your FSM here : https://wranglertjforum.com/attachments/2002-tj-service-manual-pdf.14039/
The p0320 you were getting shows the cam position sensor as possible cause.
twistedlv
Las Vegas
Read your FSM. In mine it was in a section titled Driveability - Gas. It gives a whole troubleshooting sequence for P0300 family of dtc's. Some are as simple as a vacuum leak or a worn serpentine belt. Anything that could cause the crankshaft to rotate irregularly.
I feel your pain, as I am still trying to chase down an itermittent P0301. My next step is to fab up a smoke tester to check for vacuum leaks.
Reactions: KCsTJ
T Crawford
PNW
P0301 was known as a heat soak issue on xj’s you might look into the insulation material you can put around the fuel injector
2
2002TJ
maryland
Thank you! I will look at the FSM. I replaced the serpentine belt a few months ago and will check for a vacuum leak and look into insulation material this weekend. Losing sleep over P0301.
KCsTJ
TJ student
Farmersville, TX, United States
I have a pic of a smoke tester on my 97 members rides thread. Less than 10 bucks, worked great on my 2.5 and 4.0.
KCsTJ
TJ student
@2002TJ most misfires are electrical in nature as opposed to fuel for example.
I just finished hunting down 2 different misfires, cyls 3 & 4, over a several month period on my 97 tj.
Point is, on a misfire, this could be a process as opposed to a 1 day fix.
If P301 is your only code, consider every part from the #1 spark plug all the way up the line thru the fuel injector connector all the way to the PCM could be suspect.
Check, replace 1 thing at a time and do the step by step dance till u get her done
Reactions: Rusty Rivets
