So I was out this morning and when I restarted the Jeep after stopping, I got the standard rough idle and stumble common with heat soak. I didn't think much of it, as here in Florida it tends to happen often. However, this time the check engine light came on which has never happened before. I had a few more stops on my way home, and the Jeep didn't have any more heat soak issues, but the check engine light never went off. I checked the code and came up with P0304 -cylinder 4 misfire. I unhooked the battery for 30 minutes then restarted the Jeep and the code was cleared.
Even though the check engine light has never come on before, I assumed that the code would have been for cyclinder three. Now I'm wondering if I should add the insulator to the number four injector too, or maybe this was just a fluke thing.
Any thoughts?
Any thoughts?
