My 2006 TJ Is giving an PO 431 code (means that the vehicle's control module has detected that the three-way catalytic converter is not working properly (is not as efficient as the factory is expecting). Replacing the oxygen (O2) sensors may sometimes fix the code, but in most cases the catalytic convert needs to be replaced to fix the problem. If the P0431 code is combined with other codes, try fixing the other codes first.)
has anyone had to deal with this
there are no other codes being giving
Thanks!
Thanks!
