"Pacing myself" build
I can't find the American Racing wheels in stock anywhere. Here is another option. I like the backspacing on this one.
https://www.quadratec.com/p/black-rhino/baker-wheel-wrangler-yj-tj/17x8.5-bronze-1785bkr-85114z71
Gravitating to the Toyos.
If you're talking about the bronze I dig them!
I'm not sure about the new Toyo RT Trails but have a little experience with the original RT's and hated them. Now they are drastically redesigned so that's probably not relevant, but really my only experience with Toyo and I wasn't impressed. The RT Trail looks really good though. Hope it performs well!
Reactions: bobthetj03
That combination is not trivial to find (esp in 5x5.5) which is why I went the route that I did.
But I had saved these in case it helps you.
Edit - Ah nvm, these are beadlocks. Ignore.
https://www.summitracing.com/parts/vsw-s2669
Dang! Too bad you can't find those American Racing wheels. The Black Rhino's look good too. If you could get with some bronze bolts it would be really cool. I checked all the Raceline's and you'd need a spacer to make the BS work on the few bronze offerings.
I like this one with a 2" spacer would give you 3.88 BS, which is darn near perfect to avoid some rubbing. Also way cheaper than the Rhino's at $162.75.
https://racelinewheels.com/products/946bz-boost?_pos=2&_sid=aea12c912&_ss=r&variant=32196658495568
Have you considered JL or JT wheels and tires? You can find a set of those relatively cheap and they work well with a 2" adapter.
Reactions: PNW_LJ
x2. They're readily available and cheap. Throw in the JK wheels as well (same lug pattern).
Reactions: Irun
I was hoping to stay away from spacers/adapters, not that I'm against them, just want less to deal with. It definitely limits my choices, especially with a 17 wheel. I'm not going to give up on those ARW's, but I fear they are discontinued. I may revisit JK/JL wheels to see if something stands out for me.
The nice thing about JL take offs is that you can get a set of 33" ko2s if you go with a rubicon take off set. Most seem to replace them fairly quick with 35 or 37s so there's a decent amount out there with almost new tires.
Yep...I picked up a set of 5 beadlock capable Mopar wheels and tires with only a few hundred miles on them. While these are 35s, 33s are much more common.
20231026_181951-jpg.468865
@bobthetj03, the only real downside to factory wheels vs aftermarket is if you want to run lockout hubs. You can bore the factory wheels, it's just a bit of work to get them done. Most aftermarket wheels will come bored.
FWIW, this is a set of JT wheels I run on my TJ, for wheeling only. I paid $400 for 4 wheels and 5 tires that were like new. The tires are Firestone Destination MTs. Also, I did bore these out to 2.75" for the small hub kit. I've wheeled them hard with the adapters and wouldn't let that be a concern. The only caveat there is to not forget to run thread locking compound to mate the adapters to the TJ hub.
20230704_130610-jpg.438674
Those are nice, but I like the Raceline’s better.
We need an update. Whatcha thinking’ brah?!
I agree. The Raceline's would be my first choice, if they were available. Update? Sorry, button pushing unsuccessful. That is so yesterday. Come on, you can do better than that!
Reactions: JMT
I'm regretting replacing the heater core when I was having AC issues. Not sure how to move forward.
How long did the PR heater core last?
How long have you had the 4-Seasons core? What AC Evap do you have?
